- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have just purchased a new Sony KDL-46W905A today. I cannot get the Netflix app to connect. I click on app and it gives me error NW4-8. I have been in contact with Netflix and they can't even sort it. Internet is fine - just can't connect to Netflix servers. Has anyone any ideas it's driving me nuts
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It was not working immediately but retried and it worked.
I suggest the following after downloading new Firmware
1. Refresh Internet settings
2. Power off TV from socket (starting to sound like Sony support)
Turn back on and try the NetFlix again
If still no luck then try turning on Wifi Direct - my wife got it working after changing settings so I'm relaying as much info as possible.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
I am assuming that your in the England?
Can you goto :http://www.iplocation.net
and ensure that your IP address is showing that you are located in UK.
Do you have any non-standard network settings, either on your router, or on your TV? Also, are you using a third party provider, such as unblock-us (or other DNS or VPN service?)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi I have the exact same problem
am in england UK, have Virgin Internet, all standard, Tried all fixes like turning off router, back on again, resetting tv settings and still same issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same issue with my Sony kdl55w905 which arrived this week. All other internet apps ok from tv. I am with virgin cable service in the uk ! I have a western digital media streamer that has netflix & works fine over same wireless through my router !
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi all
@macgers77 - Did you manage to resolve your issue by any chance? If so, how? Also, I don't suppose your ISP is virgin?
@taspland - Can you please confirm your TV's model? Is it the W905 model like the other two posters on this thread?
All - At what stage do you get that error message? Can you even load up the application at all?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi yes i can confirm i have the exact same model,
I get this error mesage when trying to load the application, if you click on more details and click on check your network it goes through the netflix server check very fast and gives a red cross on all 4 netflix servers with error nw-4-8 the bottom one which is internet connection has a green tick, I can confirm all other apps work fine including the SEN
many thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks Taspland for the additional info.
Can I also confirm you are all on the latest firmware? vPKG4.201EUA - I think this is the latest fw version.
Cheers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
