I have just discovered that there is no Netflix option on my Sony Bravia KDL-32CX523. We bought it March 2012 (I think). Is there any way we can watch netflix natively on it or do we need to go through an external device?
Thanks
Akis
unfortunately its not available on that device. Its on all their new Blu-ray players seemingly http://www.sony.co.uk/hub/blu-ray-disc-player
Will it ever be available though?
Hi there
Simply put, device models that are PRE-2012 will not get Netflix. There are technical reasons for this (if you want to know more, use the search facility on these forums). However, I will point you to this FAQ -
https://www.sony.co.uk/discussions/message/1265664
Hope that helps.
(NOTE: I can understand your frustration, as I was annoyed too when it was announced. I too have a 2011 model tv)
I have the Sony Bravia KDL-46EX524 I was having the same problem in the UK so I bought the £30 Google Chromecast and it has solved the problem with Netflix. A great gadget and easy to install and use. http://tinyurl.com/oew36pu
