I use VGA cable but stereo cables do not transfer audio!
Nik, on TV under VGA you have little 3,5 mm audio jack, so use him for audio connection with simple audio cable which have 3,5 mm jack on the ends, to Your PC and follow instruction from support. Click on Your grafic card and scrool down to see instruction.
Regards
Damac
