Hi there
I know this may sound a pain - but can you please do a factory reset of the TV - it can cure issues and any 'gremlins' after a FW update? Also, did these exact files play before the update?
If factory reset fails to cure the problem, can you please post back the detailed information in text format using a program called "Media Info", available HERE
PS, remove any information that may not be relevant (ie filename)
I fully understand how frustrating it is, especially when you were happy before and knew it was working to expectations. Windows Updates annoy me the most - as quite often theres a knock-on effect somewhere else.
The W805A / W807A models are very popular models, and if there was a major issue with the FW, I would have expected to see a lot more complaints. I have the W807A (same TV, silver frame), and dont have this problem. This is why i suggested a factory reset.
But yes. Fully understand your frustrations and annoyance
Update: Ive had time to reset the tv, after 10min it said there was update available so tv updated itself. I plugged in the usb and the same issue repeated itself. Not very happy with this
Just out of interest, is it the same movies you are trying to play?
(Or have you tried different ones - also have you tried a different usb stick just in case?)
To confirm, I have the following:
TV = KDL-42W807A
Firmware = PKG4.440EUA
I have successfully tested a video file on a 16GB Sony USB Drive formatted in NTFS.
So basically it comes down to the following:
All else fails, contact Sony Support
The video information is:
General
Format : Matroska
Format version : Version 2
File size : 782 MiB
Duration : 52mn 7s
Overall bit rate : 2 097 Kbps
Writing application : Stupid Ocelot
Writing library : Stupid Ocelot
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 52mn 7s
Bit rate : 1 672 Kbps
Width : 1 280 pixels
Height : 538 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.097
Stream size : 623 MiB (80%)
Writing library : x264 core 142 r2431 ac76440
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 52mn 7s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 143 MiB (18%)
Default : Yes
Forced : No
Same thing. Stops after 10 min. KDL43w808c
My KD-65XF9005 used to play everything on my flash drive, but as of maybe a couple of months ago there are some older downloads where without fail it stops playing at 59mins 38secs. Help!
