Hi there
Turning off MottionFlow should prevent any type of motion interpolation and therefore no of Soap Opera Effect. If you set MotionFlow to Cinema, it should reproduce the same frame rate of the movie (ie 24fps) - Could try that? Combined with Scene Select and Picture Mode as Cinema/Cinema 1
If you have experimented with the settings and are still not happy, I would suggest contacting Sony Support : HERE
Hi there
Try setting:
Scene = Cinema
Picture Mode = Cinema 1
And see how that goes. Personally I like MotionFlow = Clear
Hi there
