Hi there
The remote you are looking for is RM-ED002
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=1120233&brand=&model=KD-28DL11U&part=
or the classic version
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=1887643&brand=&model=KD-28DL11U&part=
In regards to the manual, you will have to do a Google search (I havent got time at the moment. Or you could get it here (for a price 😞 😞
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=1261461&brand=&model=KD-28DL11U&part=
Hope that helps.
Hi there
Hope that helps.
Thank you Quinnicus.
I have already exhausted the google searches - there are a few spoof sites out there that claim to have the download and then it some other SW they are trying to foist on you (or a virus). I believe the 28DL11U was a 'special' and therefore not as easy to find. Closest I got was the KD28dx40 - the manual looked like it was for a similar tv but quoted a RM-993 remote - so there was so much doubt.
Guess we will have to trust 4ourhouse is correct in quoting the ED-0002.
Thanks
