Hi
I just purchased the KDL50W829 on the first day the Picasa app worked straight away, now all I get is "a network error occurred retry" I also can't connect to google+ using google as my browser. I have done a factory reset but to no avail. Would really appreciate any help. Thanks
Hi there
Do other applications such as iPlayer or YouTube work on the TV? If not, you will need to check your network settings and connection on the TV. If they do work, could it be your google password is the problem?
Cool. So at least we know the network on the TV is working.
Can you confirm that you can log into Picasa / Google plus on your PC/Laptop - using the new password?
If you can do that, Go into your Google Account, Click on "Security" and then click on "Recent Activity". Do you get any messages that XX has been blocked or denied?
Also, if you have 2-step-verification, disable this for the time-being and see if that helps?
I dont suppose it was San Diago or San Mateo, CA by any chance?
See:
http://community.sony.co.uk/t5/televisions/picasa/td-p/1590685
And:
http://community.sony.co.uk/t5/televisions/picasa-login-kdl-55w829/m-p/1673049
This is one of the responses that I received from Sony a while ago, in regards to Picasa login
It's a Google issue. When you change a device or use a new device with an existing Google account Google warns you as they think your account might be hacked. Therefore you need to confirm that you're the real user by clicking on the link in the e-mail.
I am going to also assume that the Tablet might be the same too.
They are Sony authentication servers, So your account was not being hacked.
To be honest, I never did find a satisfactory "fits all" solution to this problem, for me, one day it all of a sudden worked.
I guess the next thing to try is to "unlink" Picasa completely from your Google account - Security > Account Permissions - leave for a few minutes (even reboot your router - to get a new IP address) wouldnt hurt to turn TV off and on again either - and try again.
Unfortunately thats all I have at the moment, if it still doesnt work after that, leave it for today and try again tomorrow. Google might play better tomorrow
Hi there
In regards to Picasa, I still have not managed to confirm it yet, however its looking like a problem.
More information:
http://community.sony.co.uk/t5/televisions/current-outages-oct-14-sen-applications/td-p/1803571
I am having a message saying that this service is no longer available on my TV model KDL-37EX720 (2011).
Can anyone confirm?
Btw : My Playmemories doesn't work either. Error message is wrong pin or network error. But my Music unlimited account is working (same pin). No helpful info on playmemories website- they keep restoring servers in infinity it seems.:smileyclown:
