Hi we bought the Sony bravia 32R503CBU on August 29th at the Bournemouth Currys store and everything was fine till yesterday when all of a sudden we had the tiny pop channel on no 126 and it started going funny and then went blank and said there was no signal, and other channels have done the same thing. What would you suggest as not very happy that we have only had it 2 months.
I am currently using SKY to view channels. Is it possible to view freeview channels without using SKY or Freeview box? (Is there anything built in the Android TV except YouView?)
Thanks.
maikapas wrote:I am currently using SKY to view channels. Is it possible to view freeview channels without using SKY or Freeview box? (Is there anything built in the Android TV except YouView?)
Hi there
You dont actually have to use YouView if you dont want. Simply disable it in your settings. However, YouView is basically Freeview with some added benefits.
To use Freeview, simply connect an aerial cable to the TV - one that can obtain the freeview signal that is.
