I have created a folder of mp3s on my PC (a playlist) and these are streamed using Serviio. On my Sony SMPN200 I can select that folder, select the first track and it will play, then automatically select and play the next track, and so on until the last track is played. Then it stops. What I would like, however, is to be able to loop back to the beginning and play the tracks all over again (looping).
Is this function available in the N200, or likely to be?
Rock
OK, found it now. I was searching the online manual for the word 'loop' and it found no hits. I should have searched for the word 'repeat'. It is under Options on the remote when you select the audio folder.
Rock
