Hello,
Does anyone know can i use a wireless/bluetooth keyboard and mouse for the internet browser on my HX853?
If so any success stories please?
Regards
Lippy
theres a couple of options for you, one is the media remote app for your smartphone or a program called remote keyboard lite. as far as im aware you cannot connect a normal computer keyboard via bluetooth or wireless.
