Hello,
Has anyone else had an issue with Bravia Sync?
Specifically my Home button and Options button on the TV remote stopped performing that action, and instead turned on the Blu Ray player?
Being a newbie to the TV this issue could easily be down to me, but I've looked here at the sync info http://pdf.crse.com/manuals/14HE559112/EN/brsyncset_europe_co.html and to me it just doesn't make sense?
Maybe I haven't given it enough time, but I thought Sony was in a league of it's own when it comes to usability? I'm finding the sync thing pretty confusing.
Just wondered if I'm alone in this and it's me, or there's others out there?
Thanks
Kevin
Hi there
There is nothing non-standard in your setup, which is great. However, what we need to do is trace down what the actual problem is (or which piece of equipment is causing the problems). To do this, requires a little time and patience.
#NOTE: Each time you connect or disconnect a piece of equipment, please turn the TV off (Standby mode should be OK)
At any point of the way, if the HOME and OPTIONS button fail to work on the TV, disconnect all the equipment, except for the device you have just added, and test this on its own connected to the TV.
Hopefully after all this, things work as it should, but if it doesnt, hopefully you have narrowed down what the problem is.
Good luck
Hi there
I note that you've seen the other thread about the home and options button. However its interesting that the bluray player is affected.
I think before we get too far in troubleshooting, it might be best to gather more information on your setup.
Can you please describe all the equipment that is connected to the TV (makes and models) and how it is connected (ie which cable is connected to where)?
Hi there
Good luck
Hello
sorry it's taken a few days to respond, work / kids / time etc
I'm glad to say that the factory reset worked!!
ok I had to go and amend some setting and name hdmi inputs but that's really no sweat.
A superb tv, I just wish the operator was as good!
thanks for your help
Glad to here that it was a simple case of a factory reset
