Hi
Im new to all this messaging but really need some help finding an adapter for my KDL50W829 so i can fit it to a wall mount with tilt and side to side adustment?
Have been in touch with sony uk but they are as much use as a fart in a lift.
They say there not avalable till may????????/
Has anyone got any info where i could get one from?
There are a few after market ones online but i know if i fit one and it falls off or goes wrong sony will only say i didnt fit correct adapter?
Really dont want to return this tv as well impressed with it but if i carnt have it on this mount i have no choice as my 2 year old will smash it up like my last one 😞
carnt belive sony can still sell these tvs without adapters to suit??
Edited - Profanity removed
Hi there
I can only sympathise with you on this issue. I have had a search around and cannot find another product/bracket on the market as of yet. Unfortunately you may just have to find a work-around setup (ie tabletop stand instead of wall mounting it) until the bracket becomes available.
Hi there
The solution is this (in the absence of the Sony kit). It is made by Vogels and consists of a set of bolts and spacers which hold the VESA bracket away from the TV.
It works perfectly and now my KDL-50W815 sits on its Zental stand. It is sold by
http://www.av4home.co.uk/blog/guides/wall-mounting-a-new-sony-kdl-w6-series-tv/
The guide to fitting itis here
I'm taking delivery of a kdl50w829 and the back of it looks identical to your TV. Just wondering what screws/bolts you have to remove to fit the new spacer bolts. Thanks.
If you donwload the instructions (link given on my previous post) it will become absolutely clear. There are just 4 bolts to remove and replace with those supplied. I am really pleased with this item - and Sony have never conatcted me (which they said they would) to advise availability of the Sony item which is horribly large.
Ok thanks have had a closer look now and decided to buy the kit with a suigtable bracket. I'm still waiting to hear from Sony as well.... thanks for your help!!
