I would be very grateful for advice with this. It is plugged into the internet but I had hoped that it would access iplayer etc but that isn't happening. What are my options?
Thanks
Not via the set itself - easiest way is to get any of the current Sony Blu-ray players as this will add all the functionality without the need to replace the TV,
Hi there
Unfortunately, you have a below intelligence television in regards to todays standards. Your TV supports the Sony Applicast features, which does not include things like the BBC's iPlayer.
To add Smart (ie Internet) features to your TV, you have the choice of the following 2 options
Hope that helps
