KDL42W805 3D Active Glasses
SOLVED
Can I use the 3D active glasses with a Sony Bravia KDL42W805, I've Chechen various places but can't get a definitive answer
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
The W805 is a Passive 3D TV.  Therefore Active glasses will not work, as the technology is not inter-changable.
2 REPLIES 2
Anonymous
Not applicable
Hi there
profile.country.IT.title
rooobb
Expert
By the way, passive glasses are far more cheaper than the active ones, you can even use the ones that you get at cinemas :cool:
