- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KDL42W653 - Audio System
Hi, I have Virgin Media Tivo box linked to the above model using HDMI cable. I have audio cables between the TV and a Cyrus amp. When I switch the TV speakers to the audio system setting, I get no sound at all through the amp/speakers. If I switch the TV off and on, I get sound through the speakers for a very short time until the picture appears, then the sounds disappears again! I was wondering if I got a optical audio cable between the Tivo box and the TV it might sort the problem out? Was wondering if anyone else has experienced this, or if I am doing something completely wrong!! Paul
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Can you connect your tivo box to your amp as hdmi supports both uncompressed audio and video so you now have 2 audio feeds into your tv this maybe the issue.Check audio settings in tv so that audio system is enabled
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for your reply. The Tivo box has an optical audio out, but sadly my Cyrus amp is a bit old and doesn't, so I have bought an optical audio cable (on the way from Amazon), and hope that once I connect the Tivo to by TV using that, it might send the sound down the right channels. Who knows, but fingers crossed!
And yes, I have updated the speakers setting on the tv to audio system. Sadly at the moment, that just results in no sound at all... 😞
