Hi, i recently purchased the above led 3d tv a few days ago and think its a fantastic tv. But i simply have a question regarding the gorilla glass, where the glass joins the tv frame there is about 1mm gap all around the edge so it isnt directly touching the frame. Is this normal? It works fine and has no damage but it for the money it cost i want it perfect
Ive attached a picture where you can see the gap, the picture does exagerrate it a bit but it is only about 1mm wide.
Am i just being a bit OCD?
If someone with this tv could kindly reply, i would be very grateful. Thank you
Edit: looks like this guy is experiencing the same https://www.sony.lu/discussions/message/640354#640354
I have same TV, and i've just looked around the top and i can't see any gap whatsoever. I think you should forward photo to wherever you bought it from to arrange for a replacement.
hmm was looking at the pics on sonys site and you can see a gap in this pic http://sp.sony-europe.com/da/317/126077.jpeg and another user is experiencing this aswell. Perhaps its normal?? idk i have got a 5 year warranty on it
you can also see a gap 15secs in here
