Hi does anyone know the spec of the built in blu ray in the kdl40ex43b tv,I wondered if there were compromises as there are when building an all in one product,about to buy one but couldn't find the details.Thanks Graham
Hello
Welcome to the Sony Forums
As you suggest, not a lot of detail on the product page, however the full specification is available in the usuer manual, which can be downloaded here.
Regards
Lee
Hello
Regards
Lee
