Hi there
You can do it, same process, but its not going to work for you.
The reason is that this TV is Freeview only.
Even though the TV can take a satellite connection, and display channels, it is not Freesat. Freesat is the brand behind the EPG for satellite, therefore you will not get any information in the guide. You might get Now and Next though.
Hope that clears things up.
Cheers.
Hi there
This is generally a freeview reception issue. It should work though if you do the following:
Hi there
Cheers.
