- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I'm thinking of purchasing a KDL32W654 TV but am confused as to what ariel input I need for the inbuilt freeview tuner. My flat is cabled for a SKY connection - i.e. it has a threaded F type connector on the wall, and looking at the technical spec of the set - below - I'm not sure this would be supported, and that I would need a 'normal' ariel connection and not one to a dish. Can anyone confirm this is correct or that the dish connection is supportrd by the set.
Thanks
DVB-T (digital terrestrial) | YES |
DVB-T2 (digital terrestrial) | YES |
DVB-S (digital satellite) | - |
DVB-S2 (digital satellite) | - |
DVB-C (digital cable) | YES |
CI+ | YES |
Analog | YES |
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
The F-Type connector is not supported on this TV.
To get freeview you will need an freeview aerial (on the roof). If you are absolutely sure that you do not have a normal aerial socket in your flat, you will probably need to purchase a freesat box as well. Have a hunt around first though, as almost every place has an aerial (and socket)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Many thanks for the speedy reply. Confirmend what I thought / feared!!
