I have a KDL-55W905A TV and it works fine except for one thing.
The internet connection is lost after 30 to 35 min of watching.
I am using Wifi. Before I hear that i should check at the signal... It is full...
The Network @ home is Ubiquiti UAP-AC (two of them in range of the TV).
The Router is a Ubiquiti EdgeRouter™PoE.
I have multiple other devices that do work flawless.
Program version of TV is: PKG4.510EUA
I have tested WPA2 (two different networks) and Open WLAN.
I can ping the TV:s ip-address the whole time, although the TV cannot connect to Internet.
I have done multiple factory resets on the TV.
any ideas?
best regards
Davud
