Hello!
I just bought a new SONY KDL-55W815B TV and I am quite happy with it.
I have just one simple question - is the fast zapping function available for this TV and if yes, how can I acivate it?
In the OPTIONS menu there is no settings for the fast zapping at all.
Also, on the GUIDE screen I believe I have to see a small window at the top left corner showing the ongoing channel but I see nothing - just a short info about the current program/show...
Is that normal?
Appreciate any help!
Hi there
In regards to the fast zapping function, have a read of this thread - it should answer your question:
In regards to the channel preview, I believe there is an option to turn it off or on again. Try pressing option button when on guide and see if its there, or have a look at the settings. If you absolutely cannot find it, post back and ill hunt around for it.
Quinnicus, Thank you very much for your reply - as far as I understood the fast zapping function is no longer available - they have changed it with the Discover function - quite less practicle/useble...
I tried to find a way to turn on the channel preview in the GUIDE screen but no settings in the options menu about that... If you have any time to hunt around for it I will be grateful!
Thanks!
