My RM-ED053 remote is almost dead, TV is working perfectly. RM-ED053 is not available at stores, is there any replacement for it?
You can find it on the official Sony spare partner https://uk.eetgroup.com/i/149317611-Sony-Remote-Commander-RMT-TZ120E but almost any other sony Infrared remote will work with your tv (may be some buttons less or more or named differently)
