Hi, I have purchased this set just over a week ago and have connected to my Denon AVR2000. The sound on the television has been set to the system but for no apparent reason occasionaly switches back to the TV speakers. did a software update on installation. This can happen during a programme.
Any suggestions please?
Hi there
It sounds as if its a communication failure between TV and AV Reviever. Is it the AVR-2000 or AVR-X2000? As the one without the "X" is quite old now.
Does the AV receiver switch itself off?
How is it connected to your TV (using what cable/s) - try replacing the cable.
HI
Its the new one only six weeks old. All settings seem to be correct but still keeps happening.
Its hard to know what to suggest. The TV will revert back to its own internal speakers when it does not detect an audio connection (or the connection drops) - that the reason its reverting back.
On the X2000 try turning ON the HDMI Control Functions, as well as ensuring Bravia Sync is ON on the TV.
However if they are already ON, try the opposite and turn them OFF.
