Hi there
I bought KDL 46W905A a year ago and she automatically downloaded and installed an update,
so I turned off auto updates.
On February 2014 there was a new update(174MB) which I downloaded and saved in my computer and it is still there waiting to be installed.
Now I see that there is a new update and I dont know if it is safe to install the latest update in the TV, without having installed the older one.
Can anyone help?
thank you
Hi there
It is safe to install updates without the previous one being installed. The updates include all other previous updates beforehand - so if you skip an update, its ok to install the newest.
I did it and everithing seems to be ok.
Thank you.
