Ive just updated the driver on my TV (KDL-46V5500) tried 3 different HDMI cables still nothing.... Its working fine with my samsung LCD TV - can anyone tell me what settings on this sony TV I should be adjusting?
Tried all 3 HTMI inputs and its working with the AV3 connection but this is not HD and the signal is poor.
Seems as this HDMI handshake is as poor as it gets...
Hi there
Try resetting the display settungs on the Xbox 360.
To reset the display settings of the Xbox 360 console to the default settings, follow these steps:
Did you try :
If this doesn't work, can you take the 360 round a neighbours or friends house to change the HDMI output?
I returned the 360 and got the 360 E (2013 model) and it worked with HTMI first time no prob. It also has a dedicated AV/Scard port on it for a decent backup if the HTMI dosent work but so far the HDMI is working fine.
The kinect sensor was tricky to get working with the E but when i figured out it dosent require a power source (runs off the 360 via usb) I manage dto get it working.
It seems the 1st gen 360 xbox is terrable with the HDMI handshake.
Thanks to all those who took the time to respond.
