Hi
Is it possible to connect a wireless keyboard to this Television. /KDL-46NX720/ If yes how do I do it.
Thank you, Primoz
you can either use your PC as remote keyboard downloading the application Keyboard Lite from http://www.sony.co.uk/support/en/product/KDL-46NX720/downloads/Remote_Keyboard_Lite
or you can use the media remote application on your smart phone IOS or android
