Hi all,
I have got kdl-46HX800 TV, i have connected a multimedia HDD PopCorn Hour A210 with HDMI conecxion. All works right, the videos are played perfectly. But i have a problem... when i psuh the OPTION button on the remote control, the menu doesnt appears and nothing happens. This is the menu that should appears on the right side and gives access to motionflow, scene selection, PAP, .. and 3D. i cant activate the 3D side by side option, and i cant play 3D movies
I havent the same problems with other systems conected with HDMI. I have got a Satelite Reciver and i can access to the OPTION menu and watch 3D movies side by side.
The Popcorn allows configure different video setting modes, i have try 1080p, 1080i, and others lowers... the menu doesn't appears in any of them. Only if i use a RCA conexion the menu works. Of course the quality is too poor and nice it is analogic the 3D options are disabled.
does anyone could help me with that?
Thanks you very much
