The TV has a built-in analog and DVB-C/T (no DVB-S!) receiver. A channel name (DVB-C) will be displayed with the following error message: «Selected program not available».
I tried the following and it did not help:
My Sony TV worked perfectly for about 4 years now. Currently I’m despaired and I tried several times the digital channel search. At least I can watch TV trough the extern DVB-C receiver. As I can display the channel names and an update EPG I assume, that the TV gets some data.
Does anyone have the same problem and has a tip how to solve this issue?
Hi there
Im just going through a couple of older posts that no one has responded to, are you still having problems or have you managed to fix it ?
@Anonymous
No difference so far. I even chanced the coaxial cable without any effect.
Once i managed to receive one channel, the others stayed black. After a new channel search I've got same problem as before.
I start looking for a new tv. But this time it won't be a Sony. 😞
