- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KDL 42W8
HELP
APPS [bbc iplayer] demand5 keep disapearing from app menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Sorry to hear that you are having problems. Can you please describe things in more details? Have you tried any troubleshooting yourself (as in checking to ensure that your TV is connected to your network/internet correctly).
What is the exact model of your TV, you have part of it, whats the rest?
Sorry to ask questions, but Its hard to help without more information.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
full model is KDL-42W829B
the main oroblem is on the home screen
when you sellect apps on the top bar two columns are shown
the left on shows featured apps and the right shows installed apps
the featured apps which list
bbciplayer, demand5, 4od, amazon video, itv, and others
depending on the mood of the tv depends if any of these are available mostly they are not
i have turned off auto updates and it is still happening,,, the apps can disaapear forcdays and then just re appear
thanks
andy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Your symptoms sound more like a network issue. Am I assuming that you've connected your TV to your network via wireless? If so, can you please connect an ethernet cable to the TV and change the TVs network settings to LAN cable. Then give this a test out.
Most applications will 'disapear' if the TV does not detect an internet/network connection/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
the tv is connected via ethernet conn, we are on EEfibre
net work speed 38mbps
wireless speed 29mbps
will check network speed when no apps are available
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Cool.
Just checked, the firmware version for your TV, should be : PKG2.263EUA can you check this in the support section of the TV?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm guessing here. Did you use the "plus" item in the right side box, or "All Apps" at the bottom of the screen? From either you can reach a big messy list of all apps. You can scroll the list and add your favorite apps, which will then show in the right side box.
