I tuned my new KDL-42W654A and have an aerial cable that works fine for freeview HD on a youview box (so I know there is an HD signal that is good enough to use).
When I select an HD TV channel I get a picture, then it goes black, says no signal, then I get picture again and it continuously flicks between a picture and no signal.
It never consistently shows a picture so isn't running for a few minutes then dips out,it switches between picture and black screen at least once a second so never stabilises on anything.
I have latest firmware
Does anyone have any ideas, or is this TV ultra sensitive on signal strenght such that the YouView box can work perfectly and the Sony TV just needs a much stronger signal?
Thanks if anyone can help.
Hi there
From what your saying, you have it connected it the following way?
And then the following happens
Note: Is this correct?
If the above is correct - Try doing the following on your YouView Box (Page 21 of the manaual : Here)
If that still does not resolve your problem, try the following
Hope that resolves your problems.
Cheers.
