I just bought myself the KDL-42W653A, followed the onscreen setup instructions, connected to WiFi etc. and checked the apps list, it was minimal, with only 13 apps, including the Video unlimited, music unlimited, PlayMemories online. There's no sign of BBC iPlayer, Netflix, BBC News or BBC Sport. I updated to the latest firmware, refreshed internet content, and there's still only the basic apps.
Am I missing something?
Thanks.
Hi Braadg
Can you try the following:
Did you select to view all applications ???? I have the Sony Bravia KDL-32W651A with updated firmware and has a lots of applications......!!!!!
I read Netflix is on only for US , like many other things......BBC as i read , there is applications for Sony TV's...
I have also looked a bit around the internet on how to download and install apps , on your Sony TV and you can fin lots of info....still havent tried to download and install anything, cause i am fighting with Synchronise issues...
Yes I've tried to view all, that simply gives me 2 additional applications, Photo frame and "a" clock. I've tried searching online for solutions but have had no luck as yet.
With which button are you accessing the applications...Do you go through Home or SEN ???
Hi Braadg
