The problems arise around the
options
home
guide and ifo buttons
when I press these buttons the light on base of tv interacts with remote but dosen't operate the requested programme
the only way I can access these functions is to press the I manual button and open them from there and even then the options button gives me an unavailable notification .
any ideas what im doing wrong ?
Thanks for any help
Hi there
Best guess is a faulty remote control. Doesnt hurt to change the batteries though first.
You might want to consider contacting Sony Support on this : HERE
Hi there
