can anyone advice me how I solve the problem of my Smart TV KDL-40WE663 freezing on some apps after the first advert. It is not the broadband connection, reloaded the factory settings, even had BT round to check all my broadband equipment - Still no luck, still freezing.
The system of these tvs are appalling, i updated my tv from an lg to sony because the picture is supurb BUT smart side of tv is rubbish it locks up all the time, google playstore works only if you go through the sony webpage and this may as well be taken out and go back to a laptop, i expected to use the tv like a laptop (just like lg tvs) this is nothing like it. i would gladly take it back to the shop an smash it in front of them BUT it is not the salesman fault it is the restrictions this company has put on the tvs this is my tv model no KD-49XG8096.
I cannot imagine you will get a reply from sony just lots of frustrated buyers of so called SMART TVs
I just want to be able to use the numeric keypad on the remote, rather than the on/off button, to wake the tv on a selected channel, not the channel it was using when it was switched off. This was a feature in my £90 Asda supplied Polaroid basic tv of 5 years vintage. Sony says it cannot be done! So much for smart software, none of which seem to be part of the package!
