- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KDL-40w4220
why do our tv loose the memory of the channels in digital mode
at least once a week
please help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Im not sure what you mean by 'loose' - can you explain a little more on that? How do you find the channels again?
In the mean-time, try a factory reset of the TV, as it may flush any errors in it. Be sure to write down any customised settings firsthand, as they will be lost too. Goto Settings > Setup > All Reset
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It means that after a week or so I must search for channels again
because the TV writes that there are no channels
then I start a new search by the menu
and then It works for about one week and then I must start over again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Try disabling "Auto Service Update" to see it this has the desired affect. Disabling this has the effect of channels will not be automattically updated when added or deleted. You will need to perform a re-tune for new channels periodically.
Goto Settings > Digital Setup > Technical Setup > Auto Service Update and set to OFF.
Give that a test run anyhow.
