Hi I have a kdl-40hx803 with the latest software version pkg4.114eut-0108
And I would like to know how I stop the tv from having av1 & av2 on the input list
I no longer use any of the scart ports
But there annoy me as they are still active
THese connections are embedded in this model and you would not be able to remove them,and as the sockets are physically on the device you still need this option.
