- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
In the last couple of months I have noticed when dark images are moving across the screen there is a noticable blur tailing it. Would it have been the firmware or software update that has affected it? Please let me know if anyone else is experiencing or overcome the problem. Cheers
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
what has likely happened is that when the updates was done it has put some of the settings back to default, you will need to go into the menu and see if anything you can remember when you set your tv up has been changed, you can start by changing the motionflow settings from whatever they are set to at present.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
