Batteries are Ok, Internet Connection OK,
Rebooted all.
Why ,oh why, is it so slow to get on to BBC I Player, ITV Hub, Prime, Netflix and then select?
Hey, check if your TV is running on the latest software version from here, after that refresh internet content on your TV from here. I would recommend performing a factory reset if the former don't fix the issue from here
