Can anyone recommend a cheap set of wireless headphones from either Amazon or eBay that are compatible with this TV? I really only need something in the £20-25 price bracket as it's only for occassional use.
Thanks
Hi @Andrewmorris197 Looking at the KDL-32WD756 specifications it appears that your TV does not support wireless headphones. You would need wired headphones or a transmitter that plugs into the headphone socket or possibly USB (sorry no idea if that even works).
