I've worked out how to make changes to the settings in Standard Picture Mode for Digital TV, HDMI or AV inputs so they can all be slightly different. How do I change them for 'All Apps' as well? Whenever I go into 'All Apps' from the Home button on the remote, I can see that the screen display changes to a vivid look but I can't see how to change it for that particular input mode.
Hi there
I am wondering if you have this set to ON? Try turning it off?
Thank you, Quinnicus, but I don't have Intelligent Picture Plus as an option on my TV.
Hi there
Considering that you dont have that option - I am unsure. Once apon a time, there used to be a work-around where if you go into one of the apps such as YouTube, change the picture settings and then come out again, then the other apps would work on that picture setting. Unsure if it will still work, or whether it will work on the 'all apps' homescreen.
Give that a go and see?
