How can I get of this problem? whenever I am browsing web its says too much memory is required to display this page.
"What sad moment" I even can't open facebook on Sony smart TV 32w700b this is not a good product its very basic system.
Thank you
Hi there
Instead of using going to the web-browser to use facebook, I believe that there is a "Facebook" app in the Applications section of the TV. You should use this instead and should work.
