I have a 2011 Sony Bravia tv KDL-32EX713, and I need to know how to connect this wirelessly to my upstairs PC? Is there a separate USB or HDMI device I need to purchase?
In particular I want to view/stream BBC iPlayer to the tv and have no idea how to go about it.
Many thanks and Merry Christmas!
Hi there
I note that your model TV has ceased to support BBC iPlayer since September 2016 - hence the reason why you want to stream iPlayer to the TV from your PC.
Your best bet is to purchase the Amazon Fire TV Stick:
https://www.amazon.co.uk/Amazon-Fire-TV-Stick-Streaming-Media-Player/dp/B00KAKUN3E/
Hi there
Thank you for the tip! Very helpful.
Will purchase! x
