I have ordered a KDL-24W605A from Amazon.co.uk with freeview HD and see from the specifications that the TV also supports DVB-S2.
I have a couple of questions:
Does the UK standard spec for the TV support DVB-S2 ?
Can I use a signal combiner to combine the UHF/VHF signal from my antenna with my satellite DVB-S2 signal and use the combined one cable to connect to the TV without any additional settop box ?
How do I scan both antenna and satellite channels with the above configuration ? Will I be able to see both antenna and satellite channels in the same channel list ?
Am I limited to 50 channels ?
What is the standard UK Spec for the RF connector ? Is it an F-Connector type ?
Many thanks
