- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
My remote RM-Y1011 needs to be replaced as the batteries appear to have leaked. THe TV is KDEP37XS1 Wega.
I've been unable to find a suitable replacement on line. Can you suggest an alternative remote?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello there
I have had a search for your remote and cannot find that particular model.
However as a viable alternative, have a look at the Harmony range of remote controls. I have just been to their website to see if your TV is supported, and it is.
Depending on how far your budget stretches, have a search on Amazon. I found this one for a reasonable price.
http://www.amazon.co.uk/Logitech-Harmony-650-Universal-Remote/dp/B005FQNDTO/
Please note, that this is only a suggestion. Please ensure that you do your research before purchasing any product, to ensure it suits your requirements.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello there
