I have had a Sony Bravia KD49XF7002 49 for just over a year and I am getting Ghosting on the screen on the left side and the bottom. Seems to be getting worse, was wondering if anyone has this problem. Any advice welcome. Thank you
Hi Madmonkey,
Usually this shouldn't happen except some force has been put on the frame.
I would suggest to get in touch with support as long as you're within warranty.
