I need to fit this tv on smaller cabinet but the legs are slightly too wide because of the feet pointing outwards. Is it possible to switch the legs round so they point inwards or find different legs that are straight rather than splayed out?
Hi @Don23255, i think that the stand for this set has only a single position.
To check if there are other stands you might wanna get in touch with Sony directly or check third party retailers.
You can also look for a stand suitable for the VESA predisposition on the back of the TV, the same one used for the wall brackets.
