Just purchased a KDL40EX503 and was wondering if it is possible to rename the inputs from the standard AV1 etc,
My son has learning difficulties and the old Sony TV we had you could, but not been able to find a way as yet. It would be good if you could.
You certainly can, very useful feature!
The option can be found by following: Settings - External Input - AV Presets, then scroll across to the Label AV tab. if you scroll through the preset choices of 'DVD' and the like you should come to a 'Edit' option which will allow to you put whatever you like.
More details should be in the built in i-manual but hopefully this helps in the meantime.
Best regards
L
Thnks for the prompy reply, all sorted and everyone happy. Thanks again.
i have a KDL-46HX803 and cannot for the life of me find the option to rename the HDMI 1,2,3,4 ports!!
Anyone know how?
Thanks, Roy
