My 2015 TV KDL42w705B although listed refuses to load Iplayer.
Now when I select Iplayer I get this message..
Reparse document as HTML
http/www.w3 org/TR/REC-xml/#NT-EntityRef
Can anybody explain this?
Perhaps I misjudged this I now have Iplayer working. I need a little longer to make sure all works fully and would still like a full explanation as to cause and effect.
A little more communication would not go amiss.
I am getting exactly the same message on my Bravia KDL 32W705C. It was all working perfectly a few days ago, now this is all I get. Exactly the same text.
As of 12.09.2020 my Sony KDL32w706b is getting the same error message when trying to load iPlayer.
It was working perfectly the day before.
I just posted a message
https://community.sony.co.uk/t5/android-tv/bbc-iplayer-error-message/m-p/3702728#M46931
It is now working again.
Would be interested in what caused it and why it now works and if it might happen again.
Was contemplating a Factory reset but this would have been my last resort as it's a real pain to reload all my apps and settings.
