Is there any way to enable IP control on the WD75x models?
I'd really like to use the Bavia npm module to control one of these.
Hi there
I dont know the answer - but I dount it. However I have forwarded your question onto Sony for confirmation/answer.
Hi there
I received the following answer from Sony:
"Unfortunately the 32"WD75 model does not have IP control built-in.
The models with Android OS have it built in, but for this model the only way to do it would be some kind of port modification to the Rs 232 Port, but this should probably only be attempted by professionals."
