Hi. I have KDL 26 EX 320. Been working fine. Now can't get internet. Have set up several times. It locates network and says string but won't connect. My laptop etc are all working fine. I have turned tv in and off and re entered passwords etc. why is it not working? Thanks
This sounds like a wireless issue - can you try connecting a network cable to "wire" it up, and then test that. If that works, then it confirms a wireless signal issue.
