Hi, I have a Sony Bravia TV Model KDL - 40EX403 and would like to be able to record programmes. I have been offered a WD My Book AV-TV 1TB which will supposedly meet my needs. I only watch freeview programmes and would like to be sure that the above would attach to my TV and let me record any programmes I want. Hopefully there are people out there who will be able to answer my question as I am very much an amateur as far as technical matters are concerned
Hi there
Unfortunately the KDL-40EX403 model does not have the USB recording facility. Therefore you cannot add a hard drive to the TV to enable freeview recording. You will need a dedicated recorder in order to do this.
Your welcome - I know that feeling too, all too well
If USB HDD recording not possible, what kind of recorder would be able to record what is on the TV ?
I'm seeking to record what is on the TV, & that is coming from an android streamer via HDMI.
I have a Sony RDR HXD970, but this can only record what comes through the coaxial input to the RDR, & cannot record straight from what is appearing on the TV ?
Hi there
What TV do you have, as this thread is going back a couple of years now.
Apologies yes it is, but it covers my issue.
I have a Sony KDL40EX403
Hi there
Even if USB recording was possible on your TV, it would only record from the TVs internal tuner not from a HDMI source. It is NOT possible to record from a HDMI source on any TV from any manufacturer. A computer would be required with a graphics card that supports HDMI IN as a capture card
